[Bio] / FortyEight / WebPage / UserManagement.pm Repository:
Log of /FortyEight/WebPage/UserManagement.pm
Thu Oct 18 14:25:38 2007 UTC (12 years, 7 months ago) by paarmann
Changes since 1.6: +1 -0 lines
fixed whitespace in login names
Thu Jul 26 15:05:43 2007 UTC (12 years, 10 months ago) by paczian
Changes since 1.5: +11 -4 lines
new welcome mail has links to both mg- and normal rast
Fri May 11 19:19:39 2007 UTC (13 years ago) by paarmann
Changes since 1.4: +11 -12 lines
Fri Feb 2 20:58:59 2007 UTC (13 years, 4 months ago) by paczian
Changes since 1.3: +37 -9 lines
Thu Jan 18 17:35:08 2007 UTC (13 years, 4 months ago) by paczian
changed the url of the 48 hour server to http://www.nmpdr.org/anno-server/
Tue Jan 16 20:39:13 2007 UTC (13 years, 4 months ago) by paczian
Changes since 1.1: +457 -5 lines
added groups
Fri Nov 10 17:05:11 2006 UTC (13 years, 6 months ago) by paarmann
Branch point for: fig
