[Bio] / FortyEight / WebPage / Upload.pm Repository:
Log of /FortyEight/WebPage/Upload.pm
Fri May 11 19:19:39 2007 UTC (13 years ago) by paarmann
Wed Feb 28 21:46:53 2007 UTC (13 years, 3 months ago) by paarmann
Changes since 1.7: +17 -281 lines
stub that loads upload page for genomes or metagenomes as necessary
Thu Feb 15 16:58:33 2007 UTC (13 years, 3 months ago) by paarmann
Changes since 1.6: +1 -0 lines
stripping white spaces from the GENOME_ID
Fri Feb 2 17:28:06 2007 UTC (13 years, 3 months ago) by paczian
Changes since 1.5: +9 -5 lines
path information now taken from FIG_Config
Tue Jan 30 22:35:45 2007 UTC (13 years, 4 months ago) by paczian
Changes since 1.4: +2 -1 lines
corrected path error to check_ncbi script
Tue Jan 30 22:07:05 2007 UTC (13 years, 4 months ago) by paczian
Changes since 1.3: +14 -7 lines
removed button to check ncbi, added on blur event to taxid field instead
Tue Jan 30 20:57:20 2007 UTC (13 years, 4 months ago) by paczian
corrected default value for taxonomy from 'Bacteria; ' to 'Bacteria'
Tue Jan 30 17:26:33 2007 UTC (13 years, 4 months ago) by paczian
Changes since 1.1: +35 -45 lines
modified interface
took out reformat contigs - this has been moved to the pipeline
Tue Jan 16 20:40:04 2007 UTC (13 years, 4 months ago) by paczian
initial version
