[Bio] / FortyEight / WebPage / Login.pm Repository:
Log of /FortyEight/WebPage/Login.pm
Mon Aug 20 19:38:22 2007 UTC (12 years, 10 months ago) by paarmann
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_release_2008_09_29
Changes since 1.13: +5 -5 lines
fixed text
Mon Jul 16 19:26:22 2007 UTC (13 years ago) by paczian
Changes since 1.12: +6 -0 lines
introduced bot testing
Thu Jun 14 14:55:35 2007 UTC (13 years, 1 month ago) by paczian
Changes since 1.11: +1 -4 lines
fixed security bug when resetting password
Mon Jun 4 21:06:25 2007 UTC (13 years, 1 month ago) by paczian
fixed url to old version
Mon Jun 4 20:13:58 2007 UTC (13 years, 1 month ago) by paczian
Changes since 1.9: +2 -0 lines
added message about v1.0
Fri May 11 19:19:39 2007 UTC (13 years, 2 months ago) by paarmann
Fri Apr 13 15:22:17 2007 UTC (13 years, 3 months ago) by paarmann
Changes since 1.7: +66 -30 lines
Tue Apr 10 16:02:02 2007 UTC (13 years, 3 months ago) by paarmann
Changes since 1.6: +15 -16 lines
Wed Feb 28 21:44:45 2007 UTC (13 years, 4 months ago) by paarmann
Changes since 1.5: +11 -3 lines
added init of menu when logging in
Fri Feb 2 20:58:59 2007 UTC (13 years, 5 months ago) by paczian
Tue Jan 30 18:58:51 2007 UTC (13 years, 5 months ago) by paczian
Changes since 1.3: +6 -0 lines
introductory text added
Thu Jan 18 17:35:08 2007 UTC (13 years, 5 months ago) by paczian
changed the url of the 48 hour server to http://www.nmpdr.org/anno-server/
Tue Jan 16 20:39:13 2007 UTC (13 years, 5 months ago) by paczian
Changes since 1.1: +139 -85 lines
added groups
Fri Nov 10 17:05:11 2006 UTC (13 years, 8 months ago) by paarmann
Branch point for: fig
