[Bio] / FortyEight / WebPage / Jobs.pm Repository:
Log of /FortyEight/WebPage/Jobs.pm
Fri Jun 1 18:58:31 2007 UTC (13 years, 1 month ago) by paarmann
Fri Jun 1 18:50:47 2007 UTC (13 years, 1 month ago) by paarmann
added two new phases: pchs and scenarios
Fri May 11 19:19:39 2007 UTC (13 years, 2 months ago) by paarmann
Changes since 1.6: +7 -2 lines
Fri Apr 13 15:57:39 2007 UTC (13 years, 3 months ago) by paarmann
Changes since 1.5: +4 -2 lines
Thu Apr 12 19:58:59 2007 UTC (13 years, 3 months ago) by paarmann
Wed Mar 14 17:55:41 2007 UTC (13 years, 4 months ago) by paarmann
Wed Mar 14 17:38:15 2007 UTC (13 years, 4 months ago) by paarmann
Changes since 1.2: +9 -1 lines
added info title to progress bar title (message about progress and current status)
Tue Mar 13 15:53:12 2007 UTC (13 years, 4 months ago) by paarmann
Changes since 1.1: +63 -9 lines
added progress bar color key
Wed Feb 28 21:43:45 2007 UTC (13 years, 4 months ago) by paarmann
Jobs Overview page
