[Bio] / FortyEight / WebPage / ControlCenter.pm Repository:
Log of /FortyEight/WebPage/ControlCenter.pm
Mon Nov 5 16:01:48 2007 UTC (12 years, 8 months ago) by wilke
Changes since 1.11: +76 -31 lines
new display options
Wed Oct 31 04:38:22 2007 UTC (12 years, 8 months ago) by wilke
Changes since 1.10: +30 -3 lines
added export function
Tue Oct 30 22:16:25 2007 UTC (12 years, 8 months ago) by wilke
Changes since 1.9: +9 -3 lines
fixed bug for display action , correct setting now for jobs that shouldn't be imported
Tue Oct 30 16:59:00 2007 UTC (12 years, 8 months ago) by wilke
Changes since 1.8: +6 -4 lines
added presorting by name and fixed sorting by job_id
Fri Oct 26 18:14:37 2007 UTC (12 years, 8 months ago) by wilke
Changes since 1.7: +112 -75 lines
Fri Oct 12 18:19:05 2007 UTC (12 years, 8 months ago) by wilke
print to STDDERR removed
Fri Oct 12 16:49:30 2007 UTC (12 years, 8 months ago) by wilke
Changes since 1.5: +28 -9 lines
- links to SEED Viewer and SEED changed, new Link to NCBI
- submit button now on both sides of the list
- accepted genomes are not shown anymore
- new cgi parameters : show_all and accpted to display all or only accepted jobs
Fri Oct 5 16:15:59 2007 UTC (12 years, 9 months ago) by wilke
Changes since 1.4: +3 -3 lines
open new windows for submenu actions, inserted target=_blank
Fri Oct 5 15:32:30 2007 UTC (12 years, 9 months ago) by wilke
Changes since 1.3: +8 -1 lines
open new window to see job details,
fixed missing check for DONT
Fri Sep 28 19:49:38 2007 UTC (12 years, 9 months ago) by wilke
Changes since 1.2: +116 -14 lines
Added fields to table view (Replace Genome, SEED, Import reason)
Fri May 11 19:19:39 2007 UTC (13 years, 2 months ago) by paarmann
Changes since 1.1: +119 -34 lines
Wed Feb 28 21:39:43 2007 UTC (13 years, 4 months ago) by paarmann
import to seed page
