[Bio] / FortyEight / Table.pm Repository:
Log of /FortyEight/Table.pm
Tue Feb 5 04:41:37 2008 UTC (11 years, 11 months ago) by parrello
Changes since 1.5: +12 -6 lines
Added TITLE command for Wiki.
Fri Jun 15 15:39:36 2007 UTC (12 years, 7 months ago) by paczian
fixed apache error log use of uninitialized message flow
Fri Feb 23 20:09:38 2007 UTC (12 years, 11 months ago) by paczian
always test before committing -.-
Fri Feb 23 20:01:26 2007 UTC (12 years, 11 months ago) by paczian
Changes since 1.2: +179 -89 lines
now really works :)
Fri Feb 23 19:44:21 2007 UTC (12 years, 11 months ago) by paczian
Changes since 1.1: +89 -178 lines
added support for tree, sortable column select, ...
Tue Jan 16 20:36:03 2007 UTC (13 years ago) by paczian
initial version
