[Bio] / FortyEight / SeedExport.pm Repository:
Log of /FortyEight/SeedExport.pm
Fri Sep 25 13:40:30 2009 UTC (10 years, 8 months ago) by paczian
CVS Tags: rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928
Changes since 1.11: +18 -5 lines
Diff to previous 1.11 , to selected 1.7
validated gff3 export
Wed Feb 13 18:02:11 2008 UTC (12 years, 3 months ago) by olson
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_release_2008_09_29
Changes since 1.10: +5 -1 lines
Diff to previous 1.10 , to selected 1.7
Fix exports.
Mon Feb 11 17:33:08 2008 UTC (12 years, 3 months ago) by olson
Changes since 1.9: +274 -258 lines
Diff to previous 1.9 , to selected 1.7
Support bioperl export for split contigs (genbank, embl).
Tue Oct 2 18:01:00 2007 UTC (12 years, 8 months ago) by paarmann
Changes since 1.8: +27 -11 lines
Diff to previous 1.8 , to selected 1.7
fixed export of rna, weird sourceforge bug commented out
Mon Sep 10 14:40:01 2007 UTC (12 years, 8 months ago) by paarmann
Changes since 1.7: +20 -9 lines
Revision 1.7 - (view) (download) (as text) (annotate) - [selected]
Thu Feb 15 22:41:39 2007 UTC (13 years, 3 months ago) by paarmann
Changes since 1.6: +235 -264 lines
export now is in sync with features table
Thu Feb 15 16:59:42 2007 UTC (13 years, 3 months ago) by paarmann
Changes since 1.5: +4 -3 lines
Thu Feb 8 21:11:01 2007 UTC (13 years, 3 months ago) by paarmann
Changes since 1.4: +15 -3 lines
added workaround to export gff with annotations
Fri Feb 2 20:58:00 2007 UTC (13 years, 4 months ago) by paczian
Changes since 1.3: +16 -0 lines
corrected dbxrefs and added go terms
Wed Jan 31 22:10:06 2007 UTC (13 years, 4 months ago) by paczian
Changes since 1.2: +7 -5 lines
corrected dbxref tags
Tue Jan 16 20:29:55 2007 UTC (13 years, 4 months ago) by paczian
Changes since 1.1: +51 -32 lines
initial version
Thu Jan 11 17:06:22 2007 UTC (13 years, 4 months ago) by paczian
Diff to selected 1.7
nitial version
