[Bio] / FortyEight / SeedExport.pm Repository:
Log of /FortyEight/SeedExport.pm
Links to mgrast_rel_2008_0806: (view) (download) (as text) (annotate)
Wed Feb 13 18:02:11 2008 UTC (12 years, 5 months ago) by olson
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_release_2008_09_29
Changes since 1.10: +5 -1 lines
Fix exports.
Revision 1.10 - (view) (download) (as text) (annotate) - [selected]
Mon Feb 11 17:33:08 2008 UTC (12 years, 5 months ago) by olson
Changes since 1.9: +274 -258 lines
Support bioperl export for split contigs (genbank, embl).
Tue Oct 2 18:01:00 2007 UTC (12 years, 9 months ago) by paarmann
Changes since 1.8: +27 -11 lines
Diff to previous 1.8 , to selected 1.10
fixed export of rna, weird sourceforge bug commented out
Mon Sep 10 14:40:01 2007 UTC (12 years, 10 months ago) by paarmann
Changes since 1.7: +20 -9 lines
Diff to previous 1.7 , to selected 1.10
Thu Feb 15 22:41:39 2007 UTC (13 years, 5 months ago) by paarmann
Changes since 1.6: +235 -264 lines
Diff to previous 1.6 , to selected 1.10
export now is in sync with features table
Thu Feb 15 16:59:42 2007 UTC (13 years, 5 months ago) by paarmann
Changes since 1.5: +4 -3 lines
Diff to previous 1.5 , to selected 1.10
Thu Feb 8 21:11:01 2007 UTC (13 years, 5 months ago) by paarmann
Changes since 1.4: +15 -3 lines
Diff to previous 1.4 , to selected 1.10
added workaround to export gff with annotations
Fri Feb 2 20:58:00 2007 UTC (13 years, 5 months ago) by paczian
Changes since 1.3: +16 -0 lines
Diff to previous 1.3 , to selected 1.10
corrected dbxrefs and added go terms
Wed Jan 31 22:10:06 2007 UTC (13 years, 5 months ago) by paczian
Changes since 1.2: +7 -5 lines
Diff to previous 1.2 , to selected 1.10
corrected dbxref tags
Tue Jan 16 20:29:55 2007 UTC (13 years, 6 months ago) by paczian
Changes since 1.1: +51 -32 lines
Diff to previous 1.1 , to selected 1.10
initial version
Thu Jan 11 17:06:22 2007 UTC (13 years, 6 months ago) by paczian
Diff to selected 1.10
nitial version
