[Bio] / FortyEight / Mantis.pm Repository:
Log of /FortyEight/Mantis.pm
Fri Feb 15 20:24:59 2008 UTC (12 years, 3 months ago) by olson
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_release_2008_09_29
Changes since 1.3: +13 -3 lines
Add links into the page dumper in the notes.
Fri Feb 15 19:17:39 2008 UTC (12 years, 3 months ago) by olson
Changes since 1.2: +60 -8 lines
Add new stuff to mantis support.
Rename the v1 rast frontpage to rast_v1.cgi.
Fri Oct 5 17:24:56 2007 UTC (12 years, 8 months ago) by olson
Changes since 1.1: +24 -3 lines
Mantis integration.
Thu Oct 4 22:07:31 2007 UTC (12 years, 8 months ago) by olson
initial mantis bug-create code
