[Bio] / FortyEight / Makefile Repository:
Log of /FortyEight/Makefile
Links to rast_rel_2008_04_23: (view) (download) (annotate)
Revision 1.27 - (view) (download) (annotate) - [select for diffs]
Mon Apr 7 20:07:27 2008 UTC (11 years, 9 months ago) by olson
CVS Tags: rast_rel_2008_04_23
Changes since 1.26: +2 -1 lines
Diff to previous 1.26 , to selected 1.12
Add reset-failed-rp which will fix a job which RP broke for.
Wed Apr 2 18:22:12 2008 UTC (11 years, 9 months ago) by olson
Changes since 1.25: +5 -4 lines
Diff to previous 1.25 , to selected 1.12
remove no longer used modules from the makefile
Mon Feb 11 21:45:26 2008 UTC (11 years, 11 months ago) by olson
Changes since 1.24: +1 -1 lines
Diff to previous 1.24 , to selected 1.12
Add support for deadline scheduling & job export.
Wed Feb 6 22:16:37 2008 UTC (11 years, 11 months ago) by olson
Diff to previous 1.23 , to selected 1.12
Support lustre work directory.
Wed Oct 31 23:16:50 2007 UTC (12 years, 2 months ago) by olson
Changes since 1.22: +3 -4 lines
Diff to previous 1.22 , to selected 1.12
Rollup of import changes.
Tue Oct 23 18:58:31 2007 UTC (12 years, 3 months ago) by olson
Changes since 1.21: +2 -1 lines
Diff to previous 1.21 , to selected 1.12
Add reset_stage.
Thu Oct 11 18:32:16 2007 UTC (12 years, 3 months ago) by olson
Changes since 1.20: +5 -4 lines
Diff to previous 1.20 , to selected 1.12
attribute indexer
Thu Oct 11 17:01:32 2007 UTC (12 years, 3 months ago) by mkubal
Changes since 1.19: +4 -1 lines
Diff to previous 1.19 , to selected 1.12
adding PHOBIUS and CELLO scripts
Fri Oct 5 17:25:53 2007 UTC (12 years, 3 months ago) by olson
Diff to previous 1.18 , to selected 1.12
Updates to the Teach stuff. Small mod to build_nr to support condtional setting of sort buffer size.
Wed Oct 3 20:55:54 2007 UTC (12 years, 3 months ago) by olson
Changes since 1.17: +3 -1 lines
Diff to previous 1.17 , to selected 1.12
Pipeline scripts for computing critica and glimmer calls for the Teach project.
Fri Sep 28 20:27:06 2007 UTC (12 years, 3 months ago) by olson
Diff to previous 1.16 , to selected 1.12
remove syntax check
Tue Sep 25 19:06:28 2007 UTC (12 years, 3 months ago) by mkubal
Diff to previous 1.15 , to selected 1.12
added pfam attribute generation scripts
Tue Sep 25 18:45:53 2007 UTC (12 years, 3 months ago) by olson
Diff to previous 1.14 , to selected 1.12
Add sim submission script
Thu Sep 13 19:56:29 2007 UTC (12 years, 4 months ago) by olson
Diff to previous 1.13 , to selected 1.12
new scripts
Wed Sep 5 20:59:03 2007 UTC (12 years, 4 months ago) by olson
Changes since 1.12: +6 -1 lines
Rollup of RAST->SEED import stuff.
Revision 1.12 - (view) (download) (annotate) - [selected]
Thu Jul 26 19:35:21 2007 UTC (12 years, 5 months ago) by parrello
Changes since 1.11: +5 -5 lines
Fri Jun 1 16:26:26 2007 UTC (12 years, 7 months ago) by olson
Diff to previous 1.10 , to selected 1.12
Add scenario computation.
Thu May 31 17:02:01 2007 UTC (12 years, 7 months ago) by olson
Changes since 1.9: +2 -1 lines
Diff to previous 1.9 , to selected 1.12
new stuf
Fri May 11 19:18:04 2007 UTC (12 years, 8 months ago) by paarmann
Diff to previous 1.8 , to selected 1.12
Tue Feb 27 21:00:27 2007 UTC (12 years, 10 months ago) by olson
Diff to previous 1.7 , to selected 1.12
move email support to Job48
remove stopligth status
make quality_check set up correction.status and correction.request if corrections needed
Thu Feb 1 20:03:54 2007 UTC (12 years, 11 months ago) by olson
Changes since 1.6: +2 -1 lines
Diff to previous 1.6 , to selected 1.12
rollup of 48hr fixes
Tue Jan 16 21:09:07 2007 UTC (13 years ago) by paczian
Changes since 1.5: +9 -6 lines
Diff to previous 1.5 , to selected 1.12
added subdirectory WebPage
Mon Jan 15 21:43:51 2007 UTC (13 years ago) by olson
Diff to previous 1.4 , to selected 1.12
Add bbhs support,changes to postproc sims to compute expanded sims the new way
Fri Dec 1 21:39:11 2006 UTC (13 years, 1 month ago) by olson
Changes since 1.3: +2 -1 lines
Diff to previous 1.3 , to selected 1.12
48hr fixes
Wed Nov 22 21:01:42 2006 UTC (13 years, 2 months ago) by olson
Diff to previous 1.2 , to selected 1.12
48hr mods
Tue Nov 14 17:26:14 2006 UTC (13 years, 2 months ago) by olson
Changes since 1.1: +9 -1 lines
Diff to previous 1.1 , to selected 1.12
Adding some utility stuff and the start of the master-check script.
Fri Nov 10 17:05:11 2006 UTC (13 years, 2 months ago) by paarmann
Branch point for: fig
Diff to selected 1.12
