[Bio] / FortyEight / JobUpload.pm Repository:
Log of /FortyEight/JobUpload.pm
Tue Jan 25 18:45:01 2011 UTC (9 years, 1 month ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, myrast_33, rast_rel_2011_0928
Changes since 1.11: +5 -3 lines
Limit contig ids to 70 chars on upload.
Mon Jan 24 22:23:36 2011 UTC (9 years, 1 month ago) by olson
Changes since 1.10: +4 -2 lines
Picky fix for plurality agreement.
Mon Jan 24 22:19:49 2011 UTC (9 years, 1 month ago) by olson
Changes since 1.9: +14 -0 lines
Kick out fasta uploads with ids too long.
Mon Aug 30 19:07:25 2010 UTC (9 years, 5 months ago) by olson
CVS Tags: rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
workding tweak
Thu Aug 5 18:54:34 2010 UTC (9 years, 6 months ago) by olson
CVS Tags: rast_rel_2010_0827
Changes since 1.7: +7 -2 lines
make sure we write everythign we read
Wed Jul 28 21:13:59 2010 UTC (9 years, 6 months ago) by olson
Changes since 1.6: +19 -1 lines
save sequence histogram; check for chars in contigs over 2k
Sun Jun 27 19:41:32 2010 UTC (9 years, 8 months ago) by olson
fixes for paths with spaces
Thu Apr 29 19:15:00 2010 UTC (9 years, 9 months ago) by olson
CVS Tags: rast_rel_2010_0526
Changes since 1.4: +63 -3 lines
Additional fixes to new upload.
Wed Apr 28 21:58:51 2010 UTC (9 years, 9 months ago) by olson
Changes since 1.3: +105 -13 lines
New RAST genome upload support.
Thu Oct 22 21:17:12 2009 UTC (10 years, 4 months ago) by olson
CVS Tags: rast_rel_2010_0118
Changes since 1.2: +84 -1 lines
updates
Wed Apr 1 21:08:53 2009 UTC (10 years, 10 months ago) by olson
CVS Tags: rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925
Changes since 1.1: +644 -1 lines
development chckpoint
Thu Feb 5 17:50:33 2009 UTC (11 years ago) by olson
CVS Tags: rast_rel_2009_03_26
new module for encapsulating all job upload functionality
