[Bio] / FortyEight / JobStage.pm Repository:
View of /FortyEight/JobStage.pm
Revision 1.3 - (download) (as text) (annotate)
Wed Jun 11 21:19:16 2008 UTC (11 years, 9 months ago) by olson
CVS Tags: mgrast_dev_08112011, rast_rel_2009_05_18, mgrast_dev_08022011, rast_rel_2014_0912, mgrast_dev_05262011, rast_rel_2008_12_18, mgrast_dev_04082011, rast_rel_2008_07_21, rast_rel_2010_0928, rast_2008_0924, mgrast_version_3_2, mgrast_dev_12152011, mgrast_dev_06072011, rast_rel_2008_09_30, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2014_0729, mgrast_dev_02212011, rast_rel_2010_1206, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2010_0118, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, rast_rel_2009_02_05, rast_rel_2011_0119, mgrast_rel_2008_0625, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, rast_rel_2008_10_09, mgrast_dev_04012011, rast_release_2008_09_29, mgrast_rel_2008_0806, mgrast_rel_2008_0923, mgrast_rel_2008_0919, rast_rel_2009_07_09, rast_rel_2010_0827, mgrast_rel_2008_1110, myrast_33, rast_rel_2011_0928, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2008_10_29, mgrast_dev_04052011, mgrast_dev_02222011, rast_rel_2009_03_26, mgrast_dev_10262011, rast_rel_2008_11_24, rast_rel_2008_08_07, HEAD
Changes since 1.2: +84 -0 lines
More stage methods.
package JobStage;
# Class to wrap up the common code that shows up in all of the job stage processing
# scripts.
use strict;
use Carp qw(cluck croak carp);
use Job48;
use FileHandle;
use ImportJob;
use base 'Class::Accessor';
__PACKAGE__->mk_accessors(qw(job job_name job_dir meta status_name hostname error_dir sge_dir));
sub new
    my($class, $job_type, $job_name, $job_dir) = @_;
    my $job = $job_type->new($job_dir);
    $job or die "Could not create $job_type on $job_dir: $!\n";
    my $host = `hostname`;
    chomp $host;
    my $errdir = "$job_dir/errors";
    -d $errdir or mkdir $errdir;
    my $sgedir = "$job_dir/sge_output";
    -d $sgedir or mkdir $sgedir;
    my $self = {
	job => $job,
	job_type => $job_type,
	job_name => $job_name,
	job_dir => $job_dir,
	meta => $job->meta,
	status_name => "status.$job_name",
	hostname => $host,
	error_dir => $errdir,
	sge_dir => $sgedir,
    return bless $self, $class;
sub open_error_file
    my($self, $tag, $dir) = @_;
    my $fh;
    my $file = $self->error_dir . "/$tag.stderr";
    if ($dir eq '>' or $dir eq 'w')
	$fh = new FileHandle(">$file");
    else
	$fh = new FileHandle("<$file");
    return $fh;
sub set_metadata
    my($self, $key, $value) = @_;
    $self->meta->set_metadata($key, $value);
sub get_metadata
    my($self, $key) = @_;
    return $self->meta->get_metadata($key);
sub set_qualified_metadata
    $self->meta->set_metadata($self->job_name . '.' . $key, $value);
sub get_qualified_metadata
    return $self->meta->get_metadata($self->job_name . '.' . $key);
sub log
    my($self, $msg) = @_;
    $self->meta->add_log_entry($self->job_name, $msg);
sub set_status
    my($self, $status) = @_;
    $self->meta->set_metadata($self->status_name, $status);
sub set_running
    $self->meta->set_metadata($self->job_name . ".running", $status);
=head3 run_process($tag, $cmd, @args)
Run the given command and argument list in a subshell. Stdout and stderr are collected
and written to jobdir/errors/$tag.stderr.
If the command fails, this code invokes $stage->fatal() so does not return.
=cut
sub run_process
    my($self, $tag, $cmd, @args) = @_;
    -x $cmd or $self->fatal("run_process: command $cmd is not executable");
    $self->log("running $cmd @args");
    my $pid = open(P, "-|");
    $self->log("created child $pid");
    if ($pid == 0)
	open(STDERR, ">&STDOUT");
	exec($cmd, @args);
	die "Cmd failed: $!\n";
    my $errfh = $self->open_error_file($tag, "w");
    $errfh->autoflush(1);
    while (<P>)
	print $errfh $_;
	print "$tag: $_";
    if (!close(P))
	my $msg = "error closing $tag pipe: \$?=$? \$!=$!";
	print $errfh "$msg\n";
	close($errfh);
	print "$msg\n";
	$self->fatal($msg);
    close($errfh);
    $self->log("process $cmd finishes successfully");
=head3 run_process_nofatal($tag, $cmd, @args)
If the command fails, this code invokes die.
=cut
sub run_process_nofatal
    -x $cmd or die("run_process: command $cmd is not executable");
    if ($pid == 0)
	exec($cmd, @args);
    while (<P>)
	print $errfh $_;
	print "$tag: $_";
    if (!close(P))
	close($errfh);
	print "$msg\n";
	die($msg);
    close($errfh);
sub run_process_in_shell
    my($self, $tag, $cmd) = @_;
    $self->log("running $cmd");
    my $pid = open(P, "$cmd |");
    if (!defined($pid))
	$self->fatal("run_process_in_shell(): error creating pipe from $cmd: $!");
    while (<P>)
	print $errfh $_;
	print "$tag: $_";
    if (!close(P))
	close($errfh);
	print "$msg\n";
	$self->fatal($msg);
    close($errfh);
sub open_file
    my($self, @spec) = @_;
    my $fh = FileHandle->new(@spec);
    $fh or $self->fatal("Cannot open @spec: $!");
    return $fh;
sub fatal
    $self->meta->add_log_entry($self->job_name, ['fatal error', $msg]);
    $self->meta->set_metadata($self->status_name, "error");
    $self->set_running("no");
    croak "$0: $msg";
sub warning
    $self->meta->add_log_entry($self->job_name, ['warning', $msg]);
    carp "$0: $msg";
1;
