[Bio] / FortyEight / JobStage.pm Repository:
View of /FortyEight/JobStage.pm
Revision 1.2 - (download) (as text) (annotate)
Thu Sep 13 19:56:18 2007 UTC (12 years, 8 months ago) by olson
CVS Tags: rast_rel_2008_06_18, rast_rel_2008_06_16, rast_rel_2008_04_23
Changes since 1.1: +10 -0 lines
add openfile method
package JobStage;
# Class to wrap up the common code that shows up in all of the job stage processing
# scripts.
use strict;
use Carp qw(cluck croak carp);
use Job48;
use FileHandle;
use ImportJob;
use base 'Class::Accessor';
__PACKAGE__->mk_accessors(qw(job job_name job_dir meta status_name hostname error_dir sge_dir));
sub new
    my($class, $job_type, $job_name, $job_dir) = @_;
    my $job = $job_type->new($job_dir);
    $job or die "Could not create $job_type on $job_dir: $!\n";
    my $host = `hostname`;
    chomp $host;
    my $errdir = "$job_dir/errors";
    -d $errdir or mkdir $errdir;
    my $sgedir = "$job_dir/sge_output";
    -d $sgedir or mkdir $sgedir;
    my $self = {
	job => $job,
	job_type => $job_type,
	job_name => $job_name,
	job_dir => $job_dir,
	meta => $job->meta,
	status_name => "status.$job_name",
	hostname => $host,
	error_dir => $errdir,
	sge_dir => $sgedir,
    return bless $self, $class;
sub open_error_file
    my($self, $tag, $dir) = @_;
    my $fh;
    my $file = $self->error_dir . "/$tag.stderr";
    if ($dir eq '>' or $dir eq 'w')
	$fh = new FileHandle(">$file");
    else
	$fh = new FileHandle("<$file");
    return $fh;
sub set_metadata
    my($self, $key, $value) = @_;
    $self->meta->set_metadata($key, $value);
sub get_metadata
    my($self, $key) = @_;
    return $self->meta->get_metadata($key);
sub set_qualified_metadata
    $self->meta->set_metadata($self->job_name . '.' . $key, $value);
sub get_qualified_metadata
    return $self->meta->get_metadata($self->job_name . '.' . $key);
sub log
    my($self, $msg) = @_;
    $self->meta->add_log_entry($self->job_name, $msg);
sub set_status
    my($self, $status) = @_;
    $self->meta->set_metadata($self->status_name, $status);
sub set_running
    $self->meta->set_metadata($self->job_name . ".running", $status);
=head3 run_process($tag, $cmd, @args)
Run the given command and argument list in a subshell. Stdout and stderr are collected
and written to jobdir/errors/$tag.stderr.
If the command fails, this code invokes $stage->fatal() so does not return.
=cut
sub run_process
    my($self, $tag, $cmd, @args) = @_;
    -x $cmd or $self->fatal("run_process: command $cmd is not executable");
    $self->log("running $cmd @args");
    my $pid = open(P, "-|");
    $self->log("created child $pid");
    if ($pid == 0)
	open(STDERR, ">&STDOUT");
	exec($cmd, @args);
	die "Cmd failed: $!\n";
    my $errfh = $self->open_error_file($tag, "w");
    $errfh->autoflush(1);
    while (<P>)
	print $errfh $_;
	print "$tag: $_";
    if (!close(P))
	my $msg = "error closing $tag pipe: \$?=$? \$!=$!";
	print $errfh "$msg\n";
	close($errfh);
	print "$msg\n";
	$self->fatal($msg);
    $self->log("process $cmd finishes successfully");
sub open_file
    my($self, @spec) = @_;
    my $fh = FileHandle->new(@spec);
    $fh or $self->fatal("Cannot open @spec: $!");
    return $fh;
sub fatal
    $self->meta->add_log_entry($self->job_name, ['fatal error', $msg]);
    $self->meta->set_metadata($self->status_name, "error");
    $self->set_running("no");
    croak "$0: $msg";
sub warning
    $self->meta->add_log_entry($self->job_name, ['warning', $msg]);
    carp "$0: $msg";
1;
