[Bio] / FortyEight / JobError.pm Repository:
Log of /FortyEight/JobError.pm
Tue Aug 31 06:50:02 2010 UTC (9 years, 5 months ago) by gdpusch
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.6: +4 -3 lines
Fixed error email to correct a typo.
Mon Mar 15 16:54:01 2010 UTC (9 years, 11 months ago) by olson
CVS Tags: rast_rel_2010_0526, rast_rel_2010_0827
Changes since 1.5: +21 -1 lines
Job management fixes.
Tue Aug 12 20:14:21 2008 UTC (11 years, 6 months ago) by olson
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_release_2008_09_29
Changes since 1.4: +16 -0 lines
Rollup of RAST release changes.
Tue Feb 19 22:12:34 2008 UTC (12 years ago) by olson
CVS Tags: rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21
Changes since 1.3: +88 -71 lines
Rework error reporting.
Fri Feb 15 16:42:45 2008 UTC (12 years ago) by olson
Changes since 1.2: +10 -2 lines
more workarounds for PPO API change
Thu Feb 14 18:02:25 2008 UTC (12 years ago) by olson
make it an exporter
Wed Feb 6 22:16:37 2008 UTC (12 years ago) by olson
Support lustre work directory.
