[Bio] / FortyEight / Job48.pm Repository:
Log of /FortyEight/Job48.pm
Tue May 27 23:42:10 2008 UTC (11 years, 10 months ago) by redwards
Changes since 1.29: +2 -2 lines
Diff to previous 1.29
correcting the order that the web app is called to stop an annoying error message
Thu Feb 14 18:15:14 2008 UTC (12 years, 1 month ago) by olson
CVS Tags: rast_rel_2008_04_23
Changes since 1.28: +42 -17 lines
Diff to previous 1.28
account for spurious changes in PPO API.
Mon Feb 11 21:52:45 2008 UTC (12 years, 1 month ago) by olson
Diff to previous 1.27
bugfix.
Mon Feb 11 21:45:26 2008 UTC (12 years, 1 month ago) by olson
Changes since 1.26: +64 -5 lines
Diff to previous 1.26
Add support for deadline scheduling & job export.
Fri Oct 12 20:52:36 2007 UTC (12 years, 5 months ago) by olson
Changes since 1.25: +2 -1 lines
Diff to previous 1.25
do \r\n stuff on first line of uploaded fasta.
Fri Oct 12 13:08:25 2007 UTC (12 years, 5 months ago) by gdpusch
Changes since 1.24: +2 -2 lines
Diff to previous 1.24
Also fixed CRLF,LF line terminators. (Egad, what system uses _them_ ?!?) -- /gdp
Tue Oct 9 19:31:30 2007 UTC (12 years, 5 months ago) by paarmann
Changes since 1.23: +4 -0 lines
Diff to previous 1.23
added method to read out PROJECT
Mon Oct 8 16:40:37 2007 UTC (12 years, 6 months ago) by paarmann
Changes since 1.22: +38 -0 lines
Diff to previous 1.22
added get_status_of_job for Terry
Mon Oct 8 15:27:49 2007 UTC (12 years, 6 months ago) by wilke
Changes since 1.21: +17 -7 lines
Diff to previous 1.21
changed contig method, contig ids are read from the contigs file now
Mon Oct 1 15:53:50 2007 UTC (12 years, 6 months ago) by wilke
Changes since 1.20: +3 -0 lines
Diff to previous 1.20
removed newline char after find GENOME
Fri Sep 28 20:40:42 2007 UTC (12 years, 6 months ago) by wilke
Changes since 1.19: +7 -1 lines
Diff to previous 1.19
changed `mv $tmp $file` to rename($tmp , $file) and check error status
Fri Sep 28 19:46:23 2007 UTC (12 years, 6 months ago) by wilke
Changes since 1.18: +47 -0 lines
Diff to previous 1.18
Added set_genome_name and _change_pattern_in_file
Wed Sep 26 23:16:57 2007 UTC (12 years, 6 months ago) by gdpusch
Changes since 1.17: +5 -0 lines
Diff to previous 1.17
Fixed the CR/CRLF newline problem, and `parse_genbank` clobbering the GENOME, PROJECT, and TAXONOMY files. -- /gdp
Tue Sep 25 01:14:57 2007 UTC (12 years, 6 months ago) by olson
Changes since 1.16: +1 -0 lines
Diff to previous 1.16
rollup of chagnes
Tue Sep 11 16:44:41 2007 UTC (12 years, 6 months ago) by paarmann
Changes since 1.15: +6 -5 lines
fix in metagenome upload
Wed Sep 5 20:59:03 2007 UTC (12 years, 7 months ago) by olson
Changes since 1.14: +12 -1 lines
Rollup of RAST->SEED import stuff.
Mon Jul 23 19:51:59 2007 UTC (12 years, 8 months ago) by paarmann
Mon Jul 23 19:50:07 2007 UTC (12 years, 8 months ago) by paarmann
Changes since 1.12: +2 -1 lines
Mon Jul 23 19:24:43 2007 UTC (12 years, 8 months ago) by paarmann
Changes since 1.11: +14 -1 lines
Tue Jul 10 19:32:22 2007 UTC (12 years, 8 months ago) by olson
Changes since 1.10: +15 -1 lines
Some minor mg assignment fixes
Thu Jun 7 14:31:24 2007 UTC (12 years, 10 months ago) by paczian
Changes since 1.9: +2 -0 lines
added meta info and returned error message when invalid file format during upload error occurs.
Fri May 11 21:57:55 2007 UTC (12 years, 10 months ago) by olson
change email references from 48-hour to RAST
Fri May 11 19:15:39 2007 UTC (12 years, 10 months ago) by paarmann
Changes since 1.7: +35 -5 lines
Thu Apr 12 19:21:15 2007 UTC (12 years, 11 months ago) by paarmann
Tue Mar 13 16:38:06 2007 UTC (13 years ago) by paarmann
Changes since 1.5: +142 -2 lines
Tue Feb 27 21:00:27 2007 UTC (13 years, 1 month ago) by olson
Changes since 1.4: +52 -0 lines
move email support to Job48
remove stopligth status
make quality_check set up correction.status and correction.request if corrections needed
Fri Feb 2 22:17:20 2007 UTC (13 years, 2 months ago) by olson
Changes since 1.3: +2 -1 lines
add/fix email and automatic continuation support
Fri Feb 2 16:42:52 2007 UTC (13 years, 2 months ago) by olson
Changes since 1.2: +4 -3 lines
use FIG_Config for jobs direcotry(backend)
Thu Feb 1 20:03:54 2007 UTC (13 years, 2 months ago) by olson
Changes since 1.1: +19 -0 lines
rollup of 48hr fixes
Tue Jan 16 21:37:23 2007 UTC (13 years, 2 months ago) by olson
Add module to wrap up 48hr job lookups
Add script to find genomes in 48hr that aren't in seed.
Make BBHs colored purple on cluster cartoon
