[Bio] / FortyEight / Job48.pm Repository:
Log of /FortyEight/Job48.pm
Wed Jul 28 21:46:19 2010 UTC (9 years, 4 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928
Changes since 1.41: +2 -0 lines
Diff to previous 1.41
Push the GENOME/TAXONOMY/PROJECT files down into the raw genome directory so the
ones the user picked are the ones that are used.
Wed Apr 28 21:58:51 2010 UTC (9 years, 7 months ago) by olson
CVS Tags: rast_rel_2010_0526
Changes since 1.40: +259 -208 lines
Diff to previous 1.40
New RAST genome upload support.
Wed Apr 7 15:31:32 2010 UTC (9 years, 8 months ago) by paczian
Changes since 1.39: +10 -2 lines
Diff to previous 1.39
added support for reserved jobs
Tue Dec 22 21:55:03 2009 UTC (9 years, 11 months ago) by olson
CVS Tags: rast_rel_2010_0118
Changes since 1.38: +38 -5 lines
Diff to previous 1.38
add non_active flag to job creation; start of upload-tarfile code.
Wed Oct 28 15:44:46 2009 UTC (10 years, 1 month ago) by olson
Changes since 1.37: +9 -5 lines
Diff to previous 1.37
minor tweaks
Thu Mar 26 18:55:18 2009 UTC (10 years, 8 months ago) by olson
CVS Tags: rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925
Changes since 1.36: +5 -5 lines
Diff to previous 1.36
I will get this right eventually.
Thu Mar 26 18:54:00 2009 UTC (10 years, 8 months ago) by olson
Changes since 1.35: +4 -4 lines
Diff to previous 1.35
typo
Thu Mar 26 18:52:29 2009 UTC (10 years, 8 months ago) by olson
Changes since 1.34: +5 -0 lines
Diff to previous 1.34
fix find_job_fileserver: if df returns /dev, the fileserver is the local hostname.
Wed Mar 25 21:49:03 2009 UTC (10 years, 8 months ago) by olson
Changes since 1.33: +50 -0 lines
Diff to previous 1.33
Rollup of some bob-rast changes.
Fri Jan 23 18:20:12 2009 UTC (10 years, 10 months ago) by dsouza
CVS Tags: rast_rel_2009_02_05
Changes since 1.32: +11 -41 lines
Diff to previous 1.32
Deleted old unused code from getUserObject which was breaking stuff.
Mon Jul 14 16:08:46 2008 UTC (11 years, 4 months ago) by olson
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_release_2008_09_29
Changes since 1.31: +14 -2 lines
Diff to previous 1.31
Fix bug in check_jobs
Job48 checks $FIG_Config::meta_use_db before createing GenomeMetaDB-based metafiles.
MGRAST configs set to use that flag.
Fri Jun 20 20:09:05 2008 UTC (11 years, 5 months ago) by olson
Changes since 1.30: +9 -2 lines
Diff to previous 1.30
Rollup of MGRAST changes.
Tue May 27 23:42:10 2008 UTC (11 years, 6 months ago) by redwards
Changes since 1.29: +2 -2 lines
Diff to previous 1.29
correcting the order that the web app is called to stop an annoying error message
Thu Feb 14 18:15:14 2008 UTC (11 years, 9 months ago) by olson
CVS Tags: rast_rel_2008_04_23
Changes since 1.28: +42 -17 lines
Diff to previous 1.28
account for spurious changes in PPO API.
Mon Feb 11 21:52:45 2008 UTC (11 years, 10 months ago) by olson
Diff to previous 1.27
bugfix.
Mon Feb 11 21:45:26 2008 UTC (11 years, 10 months ago) by olson
Changes since 1.26: +64 -5 lines
Diff to previous 1.26
Add support for deadline scheduling & job export.
Fri Oct 12 20:52:36 2007 UTC (12 years, 2 months ago) by olson
Changes since 1.25: +2 -1 lines
Diff to previous 1.25
do \r\n stuff on first line of uploaded fasta.
Fri Oct 12 13:08:25 2007 UTC (12 years, 2 months ago) by gdpusch
Changes since 1.24: +2 -2 lines
Diff to previous 1.24
Also fixed CRLF,LF line terminators. (Egad, what system uses _them_ ?!?) -- /gdp
Tue Oct 9 19:31:30 2007 UTC (12 years, 2 months ago) by paarmann
Changes since 1.23: +4 -0 lines
Diff to previous 1.23
added method to read out PROJECT
Mon Oct 8 16:40:37 2007 UTC (12 years, 2 months ago) by paarmann
Changes since 1.22: +38 -0 lines
Diff to previous 1.22
added get_status_of_job for Terry
Mon Oct 8 15:27:49 2007 UTC (12 years, 2 months ago) by wilke
Changes since 1.21: +17 -7 lines
Diff to previous 1.21
changed contig method, contig ids are read from the contigs file now
Mon Oct 1 15:53:50 2007 UTC (12 years, 2 months ago) by wilke
Changes since 1.20: +3 -0 lines
Diff to previous 1.20
removed newline char after find GENOME
Fri Sep 28 20:40:42 2007 UTC (12 years, 2 months ago) by wilke
Changes since 1.19: +7 -1 lines
Diff to previous 1.19
changed `mv $tmp $file` to rename($tmp , $file) and check error status
Fri Sep 28 19:46:23 2007 UTC (12 years, 2 months ago) by wilke
Changes since 1.18: +47 -0 lines
Diff to previous 1.18
Added set_genome_name and _change_pattern_in_file
Wed Sep 26 23:16:57 2007 UTC (12 years, 2 months ago) by gdpusch
Changes since 1.17: +5 -0 lines
Diff to previous 1.17
Fixed the CR/CRLF newline problem, and `parse_genbank` clobbering the GENOME, PROJECT, and TAXONOMY files. -- /gdp
Tue Sep 25 01:14:57 2007 UTC (12 years, 2 months ago) by olson
Changes since 1.16: +1 -0 lines
Diff to previous 1.16
rollup of chagnes
Tue Sep 11 16:44:41 2007 UTC (12 years, 3 months ago) by paarmann
Changes since 1.15: +6 -5 lines
fix in metagenome upload
Wed Sep 5 20:59:03 2007 UTC (12 years, 3 months ago) by olson
Changes since 1.14: +12 -1 lines
Rollup of RAST->SEED import stuff.
Mon Jul 23 19:51:59 2007 UTC (12 years, 4 months ago) by paarmann
Mon Jul 23 19:50:07 2007 UTC (12 years, 4 months ago) by paarmann
Changes since 1.12: +2 -1 lines
Mon Jul 23 19:24:43 2007 UTC (12 years, 4 months ago) by paarmann
Changes since 1.11: +14 -1 lines
Tue Jul 10 19:32:22 2007 UTC (12 years, 5 months ago) by olson
Changes since 1.10: +15 -1 lines
Some minor mg assignment fixes
Thu Jun 7 14:31:24 2007 UTC (12 years, 6 months ago) by paczian
Changes since 1.9: +2 -0 lines
added meta info and returned error message when invalid file format during upload error occurs.
Fri May 11 21:57:55 2007 UTC (12 years, 7 months ago) by olson
change email references from 48-hour to RAST
Fri May 11 19:15:39 2007 UTC (12 years, 7 months ago) by paarmann
Changes since 1.7: +35 -5 lines
Thu Apr 12 19:21:15 2007 UTC (12 years, 8 months ago) by paarmann
Tue Mar 13 16:38:06 2007 UTC (12 years, 9 months ago) by paarmann
Changes since 1.5: +142 -2 lines
Tue Feb 27 21:00:27 2007 UTC (12 years, 9 months ago) by olson
Changes since 1.4: +52 -0 lines
move email support to Job48
remove stopligth status
make quality_check set up correction.status and correction.request if corrections needed
Fri Feb 2 22:17:20 2007 UTC (12 years, 10 months ago) by olson
Changes since 1.3: +2 -1 lines
add/fix email and automatic continuation support
Fri Feb 2 16:42:52 2007 UTC (12 years, 10 months ago) by olson
Changes since 1.2: +4 -3 lines
use FIG_Config for jobs direcotry(backend)
Thu Feb 1 20:03:54 2007 UTC (12 years, 10 months ago) by olson
Changes since 1.1: +19 -0 lines
rollup of 48hr fixes
Tue Jan 16 21:37:23 2007 UTC (12 years, 10 months ago) by olson
Add module to wrap up 48hr job lookups
Add script to find genomes in 48hr that aren't in seed.
Make BBHs colored purple on cluster cartoon
