[Bio] / FluxAnalyzerGen / makeTextBasedFluxMap Repository:
Log of /FluxAnalyzerGen/makeTextBasedFluxMap
Sun May 18 00:15:55 2003 UTC (17 years ago) by efrank
CVS Tags: HEAD, ldrd-2003-01
Changes since 1.1: +13 -0 lines
MakeFluxAnalyzerFiles:
	top level script to drive the process
FluxAnalyzerGen:
	removed the hardwired code to generate text-based maps.  now reads
	a geometry file that describes box placement in a real flux map
	image.  that can be generatd with FluxMapMaker
	this is still useful if fixed...for bigger models.  but is now
	broken
Tue Feb 18 17:19:37 2003 UTC (17 years, 3 months ago) by efrank
Branch: newPackage
CVS Tags: notag
Diff to previous 1.1 , to next main 1.2
initial creation of package in the repo.  not really an import.
Branch point for: newPackage
