[Bio] / FluxAnalyzerGen / MakeFluxAnalyzerFiles Repository:
Log of /FluxAnalyzerGen/MakeFluxAnalyzerFiles
Sun May 18 00:15:55 2003 UTC (17 years ago) by efrank
CVS Tags: HEAD, ldrd-2003-01
MakeFluxAnalyzerFiles:
	top level script to drive the process
FluxAnalyzerGen:
	removed the hardwired code to generate text-based maps.  now reads
	a geometry file that describes box placement in a real flux map
	image.  that can be generatd with FluxMapMaker
makeTextBasedFluxMap
	this is still useful if fixed...for bigger models.  but is now
	broken
