[Bio] / FigWebServices / webservices_seed.cgi Repository:
Log of /FigWebServices/webservices_seed.cgi
Wed Aug 18 20:04:41 2010 UTC (9 years, 3 months ago) by redwards
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.7: +53 -23 lines
Changing FigFams/FigFam to FFs/FF
Tue Dec 29 06:49:38 2009 UTC (9 years, 10 months ago) by redwards
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526
Changes since 1.6: +24 -16 lines
updating search_and_grep
Mon Dec 28 23:36:16 2009 UTC (9 years, 10 months ago) by redwards
Changes since 1.5: +319 -172 lines
replacing with new version (this used to be the "complex" one).
Revision 1.5
Mon Dec 28 23:34:56 2009 UTC (9 years, 10 months ago) by redwards
Changes since 1.4: +0 -0 lines
FILE REMOVED
removing file to replace it with appropriately named substitute
Mon Dec 28 23:28:41 2009 UTC (9 years, 10 months ago) by redwards
Changes since 1.3: +46 -0 lines
final commit of a separate "complex" version of seed webservices. Moving over to this permanently
Sat Aug 29 22:00:03 2009 UTC (10 years, 2 months ago) by redwards
CVS Tags: rast_rel_2009_0925
Changes since 1.2: +38 -0 lines
updated web services
Wed Dec 3 03:38:59 2008 UTC (10 years, 11 months ago) by redwards
CVS Tags: rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09
Changes since 1.1: +38 -0 lines
adding get_corresponding_ids method
Thu May 29 23:58:31 2008 UTC (11 years, 5 months ago) by redwards
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_release_2008_09_29
Adding new wsdl/web service components
