[Bio] / FigWebServices / wc.cgi Repository:
Log of /FigWebServices/wc.cgi
Wed Sep 30 16:39:59 2015 UTC (4 years, 2 months ago) by olson
CVS Tags: HEAD
Diff to previous 1.18 , to selected 1.12
Add change from Ross's code.
Tue Jul 28 01:20:49 2015 UTC (4 years, 4 months ago) by overbeek
Changes since 1.17: +0 -52 lines
Diff to previous 1.17 , to selected 1.12
clip bad header
Tue Jul 28 01:02:04 2015 UTC (4 years, 4 months ago) by overbeek
Changes since 1.16: +54 -1 lines
Diff to previous 1.16 , to selected 1.12
carry base forward
Wed Jul 22 22:15:45 2015 UTC (4 years, 4 months ago) by overbeek
Diff to previous 1.15 , to selected 1.12
fixes for reactions
Thu Jun 25 20:05:56 2015 UTC (4 years, 5 months ago) by olson
Changes since 1.14: +16 -16 lines
Diff to previous 1.14 , to selected 1.12
my => our for CGI compilation for plack.
Sat Jun 20 13:21:39 2015 UTC (4 years, 5 months ago) by overbeek
Changes since 1.13: +46 -31 lines
Diff to previous 1.13 , to selected 1.12
allow usr to specify cs directory to use
Thu Jul 17 19:09:58 2014 UTC (5 years, 4 months ago) by olson
CVS Tags: rast_rel_2014_0912
Changes since 1.12: +20 -3 lines
Re-merge RAST chagnes.
Revision 1.12 - (view) (download) (annotate) - [selected]
Thu Jul 17 15:44:26 2014 UTC (5 years, 4 months ago) by overbeek
BAD
Mon Jul 14 17:58:10 2014 UTC (5 years, 5 months ago) by overbeek
Changes since 1.10: +6 -2 lines
Diff to previous 1.10 , to selected 1.12
added gains losses of reactions
Sun Jul 13 19:48:09 2014 UTC (5 years, 5 months ago) by overbeek
Changes since 1.9: +45 -24 lines
Diff to previous 1.9 , to selected 1.12
added reactions
Mon Jun 2 18:41:21 2014 UTC (5 years, 6 months ago) by olson
CVS Tags: rast_rel_2014_0729
Changes since 1.8: +18 -2 lines
Diff to previous 1.8 , to selected 1.12
mods for rast interation
Tue May 27 16:31:49 2014 UTC (5 years, 6 months ago) by overbeek
Diff to previous 1.7 , to selected 1.12
help documentation
Wed May 21 15:33:07 2014 UTC (5 years, 6 months ago) by olson
Changes since 1.6: +0 -48 lines
Diff to previous 1.6 , to selected 1.12
Remove header.
Thu May 15 14:35:08 2014 UTC (5 years, 7 months ago) by overbeek
Changes since 1.5: +63 -0 lines
Diff to previous 1.5 , to selected 1.12
minor
Thu May 15 14:28:25 2014 UTC (5 years, 7 months ago) by overbeek
Changes since 1.4: +0 -48 lines
Diff to previous 1.4 , to selected 1.12
minor changes to help
Wed May 14 19:14:33 2014 UTC (5 years, 7 months ago) by overbeek
Diff to previous 1.3 , to selected 1.12
wc1->wc
Wed May 14 19:00:25 2014 UTC (5 years, 7 months ago) by overbeek
Changes since 1.2: +11 -33 lines
Diff to previous 1.2 , to selected 1.12
add help
Mon May 12 18:02:02 2014 UTC (5 years, 7 months ago) by overbeek
Changes since 1.1: +20 -253 lines
Diff to previous 1.1 , to selected 1.12
wc interface restructured
Sun May 11 23:17:30 2014 UTC (5 years, 7 months ago) by overbeek
Diff to selected 1.12
initial copy
