[Bio] / FigWebServices / users.cgi Repository:
Log of /FigWebServices/users.cgi
Links to rast_rel_2008_08_07: (view) (download) (annotate)
Mon Dec 5 19:12:12 2005 UTC (14 years ago) by olson
add license words
Mon Jan 10 22:53:30 2005 UTC (14 years, 11 months ago) by olson
Add simple interface for user management. Right now it just handles the
'assignmetns accepted' parameter on users.
