[Bio] / FigWebServices / tyra_sequence.cgi Repository:
Log of /FigWebServices/tyra_sequence.cgi
Links to rast_2008_0924: (view) (download) (annotate)
Revision 1.2 - (view) (download) (annotate) - [selected]
Mon Dec 18 23:19:23 2006 UTC (13 years, 5 months ago) by hwang
add modified sequences
Mon Nov 13 17:24:05 2006 UTC (13 years, 6 months ago) by hwang
Diff to selected 1.2
This cgi gets the tyrA and the other tyrAs in that group
