[Bio] / FigWebServices / tree_jnlp.cgi Repository:
Log of /FigWebServices/tree_jnlp.cgi
Links to rast_release_2008_09_29: (view) (download) (annotate)
Tue Mar 25 18:25:49 2008 UTC (12 years ago) by disz
Changes since 1.1: +8 -2 lines
Fixed  href error in the jnlp
Tue Mar 25 16:51:28 2008 UTC (12 years ago) by disz
Generates the jnlp file for the java tree based annotation
