[Bio] / FigWebServices / testGetUniprotKbPrimaryAccessionsForFigIdServer.cgi Repository:
Log of /FigWebServices/testGetUniprotKbPrimaryAccessionsForFigIdServer.cgi
Links to rast_rel_2008_06_16: (view) (download) (annotate)
Tue Feb 7 17:17:26 2006 UTC (14 years ago) by efrank
server side for caBIG related regression tests.
