[Bio] / FigWebServices / testGetFigIdsForUniprotKbPrimaryAccessionServer.cgi Repository:
Log of /FigWebServices/testGetFigIdsForUniprotKbPrimaryAccessionServer.cgi
Links to rast_release_2008_09_29: (view) (download) (annotate)
Tue Feb 7 17:17:26 2006 UTC (14 years, 1 month ago) by efrank
server side for caBIG related regression tests.
