[Bio] / FigWebServices / testGetFigIdsForUniprotKbPrimaryAccessionServer.cgi Repository:
Log of /FigWebServices/testGetFigIdsForUniprotKbPrimaryAccessionServer.cgi
Tue Feb 7 17:17:26 2006 UTC (13 years, 9 months ago) by efrank
server side for caBIG related regression tests.
