[Bio] / FigWebServices / targets.cgi Repository:
Log of /FigWebServices/targets.cgi
Links to rast_rel_2014_0729: (view) (download) (annotate)
Wed Sep 3 20:36:36 2008 UTC (11 years, 6 months ago) by parrello
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Changes since 1.8: +9 -225 lines
Converted to work correctly with the wiki.
Tue Apr 29 08:19:31 2008 UTC (11 years, 11 months ago) by parrello
Fixed. Deprecated ScriptSetup methods are no longer exported by Tracer.
Tue Apr 10 04:08:15 2007 UTC (12 years, 11 months ago) by parrello
CVS Tags: rast_rel_2008_04_23
Changes since 1.6: +6 -10 lines
Fixed a bug in the handling of the category column.
Mon Dec 11 19:49:44 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.5: +45 -33 lines
Fixed performance of organism searches. Added best hit to human. Shortened category names, and fixed a glitch with the header row.
Thu Dec 7 00:36:39 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.4: +2 -1 lines
Added tracing.
Wed Dec 6 23:50:46 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.3: +55 -63 lines
Fixed a performance problem in the file reader. Converted to use Unix files instead of Mac files.
Thu Nov 30 23:02:10 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.2: +3 -21 lines
Moved explanatory text to the template.
Wed Nov 29 20:26:25 2006 UTC (13 years, 4 months ago) by parrello
Fixed a compiler warning.
Tue Nov 28 21:52:10 2006 UTC (13 years, 4 months ago) by parrello
New script for drug targets.
