[Bio] / FigWebServices / ssa2.cgi Repository:
Log of /FigWebServices/ssa2.cgi
Links to rast_rel_2008_06_16: (view) (download) (annotate)
Revision 1.50 - (view) (download) (annotate) - [select for diffs]
Mon Dec 5 19:12:12 2005 UTC (14 years, 2 months ago) by olson
Changes since 1.49: +17 -0 lines
Diff to previous 1.49
add license words
Revision 1.49 - (view) (download) (annotate) - [select for diffs]
Sun Jan 23 23:53:16 2005 UTC (15 years ago) by golsen
Changes since 1.48: +48 -67 lines
Diff to previous 1.48
More adding order options to Pick Organisms to Extend list
Revision 1.48 - (view) (download) (annotate) - [select for diffs]
Sun Jan 23 19:48:56 2005 UTC (15 years ago) by golsen
Changes since 1.47: +61 -14 lines
Diff to previous 1.47
Add order options to Pick Organisms to Extend list
Revision 1.47 - (view) (download) (annotate) - [select for diffs]
Fri Dec 17 22:39:46 2004 UTC (15 years, 2 months ago) by mkubal
Changes since 1.46: +27 -7 lines
Diff to previous 1.46
be able to see other ss for roles
Revision 1.46 - (view) (download) (annotate) - [select for diffs]
Wed Dec 1 19:10:08 2004 UTC (15 years, 2 months ago) by mkubal
Changes since 1.45: +7 -5 lines
Diff to previous 1.45
ssa2.cgi with auto-extend for cyanos and NMPDR
Revision 1.45 - (view) (download) (annotate) - [select for diffs]
Sat Nov 13 03:45:44 2004 UTC (15 years, 3 months ago) by mkubal
Changes since 1.44: +10 -9 lines
Diff to previous 1.44
revised path and NMPDR extend
Revision 1.44 - (view) (download) (annotate) - [select for diffs]
Sat Nov 13 02:57:24 2004 UTC (15 years, 3 months ago) by mkubal
Changes since 1.43: +204 -2 lines
Diff to previous 1.43
added cyanos and NMPDR extend
Revision 1.43 - (view) (download) (annotate) - [select for diffs]
Wed Sep 1 18:15:45 2004 UTC (15 years, 5 months ago) by mkubal
Changes since 1.42: +8 -1 lines
Diff to previous 1.42
added genome counter to ssa2.cgi
Revision 1.42 - (view) (download) (annotate) - [select for diffs]
Tue Aug 31 14:18:27 2004 UTC (15 years, 5 months ago) by redwards
Changes since 1.41: +2 -2 lines
Diff to previous 1.41
Added the number of contigs in the sequence to the Pick Organisms to Extend with list.
This is an approximate indicator of sequence quality.
Revision 1.41 - (view) (download) (annotate) - [select for diffs]
Tue Aug 31 14:14:55 2004 UTC (15 years, 5 months ago) by redwards
Changes since 1.40: +3 -2 lines
Diff to previous 1.40
Maintains the state of the ignore alternatives checkbox
Revision 1.40 - (view) (download) (annotate) - [select for diffs]
Mon Aug 23 21:46:44 2004 UTC (15 years, 5 months ago) by redwards
Changes since 1.39: +2 -1 lines
Diff to previous 1.39
Added javascript buttons for check all/none
Added color for annotations that are not the same as the primary annotations
Revision 1.39 - (view) (download) (annotate) - [select for diffs]
Tue Aug 10 01:10:05 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.38: +12 -2 lines
Diff to previous 1.38
fix colors on ssa2.cgi
Revision 1.38 - (view) (download) (annotate) - [select for diffs]
Mon Aug 9 11:52:36 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.37: +29 -20 lines
Diff to previous 1.37
fixes to ssa2.cgi relating to alternatives
Revision 1.37 - (view) (download) (annotate) - [select for diffs]
Mon Aug 9 04:20:36 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.36: +58 -35 lines
Diff to previous 1.36
handle alternatives on mismatches
Revision 1.36 - (view) (download) (annotate) - [select for diffs]
Sun Aug 8 23:43:27 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.35: +124 -28 lines
Diff to previous 1.35
include alternatives in ssa2.cgi
Revision 1.35 - (view) (download) (annotate) - [select for diffs]
Thu Aug 5 19:01:11 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.34: +1 -1 lines
Diff to previous 1.34
clean out env samples from spreadsheets
Revision 1.34 - (view) (download) (annotate) - [select for diffs]
Wed Aug 4 23:00:05 2004 UTC (15 years, 6 months ago) by gdpusch
Changes since 1.33: +4 -3 lines
Diff to previous 1.33
Fixed invocation of `align_with_clustal`
Revision 1.33 - (view) (download) (annotate) - [select for diffs]
Wed Aug 4 19:42:10 2004 UTC (15 years, 6 months ago) by olson
Diff to previous 1.32
quote argument to rm -rf
Revision 1.32 - (view) (download) (annotate) - [select for diffs]
Wed Aug 4 19:35:04 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.31: +1 -1 lines
Diff to previous 1.31
force peg ids to stack in spreadsheet cells
Revision 1.31 - (view) (download) (annotate) - [select for diffs]
Sun Jul 25 21:48:15 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.30: +17 -35 lines
Diff to previous 1.30
sort links
Revision 1.30 - (view) (download) (annotate) - [select for diffs]
Fri Jul 23 01:33:38 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.29: +1 -1 lines
Diff to previous 1.29
fixed minor bug in ssa2.cgi
Revision 1.29 - (view) (download) (annotate) - [select for diffs]
Fri Jul 23 01:28:31 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.28: +5 -1 lines
Diff to previous 1.28
fix minor errors associated with subsets in subsystems
Revision 1.28 - (view) (download) (annotate) - [select for diffs]
Tue Jul 20 18:20:14 2004 UTC (15 years, 7 months ago) by olson
Changes since 1.27: +3 -0 lines
Diff to previous 1.27
changes to delete subsystem_index entries when a subsystem is deleted
Revision 1.27 - (view) (download) (annotate) - [select for diffs]
Tue Jul 20 01:48:42 2004 UTC (15 years, 7 months ago) by overbeek
Changes since 1.26: +8 -1 lines
Diff to previous 1.26
add a few comments to the ssa2.cgi script to explain how to copy and merge subsystems
Sun Jul 18 22:58:36 2004 UTC (15 years, 7 months ago) by overbeek
Changes since 1.25: +207 -16 lines
Diff to previous 1.25
handle bug that lost notes for subsystems
Sat Jul 17 12:14:37 2004 UTC (15 years, 7 months ago) by overbeek
Changes since 1.24: +1 -1 lines
Diff to previous 1.24
show subsystems sorted
Fri Jul 16 20:41:26 2004 UTC (15 years, 7 months ago) by overbeek
Changes since 1.23: +30 -40 lines
Diff to previous 1.23
updates to ssa2.cgi and warnings when assignments fail
Thu Jul 1 21:27:15 2004 UTC (15 years, 7 months ago) by olson
Diff to previous 1.22
Join fids in spreadsheet with " " instead of "," so web browser
table renderers will split lines when necessary.
Tue Jun 29 14:15:57 2004 UTC (15 years, 7 months ago) by olson
Changes since 1.21: +2 -2 lines
Diff to previous 1.21
Fix
Mon Jun 28 20:13:34 2004 UTC (15 years, 7 months ago) by olson
Changes since 1.20: +23 -1 lines
Diff to previous 1.20
Add <a name> tags to subsystem spreadsheet.
Fri Jun 18 15:57:30 2004 UTC (15 years, 8 months ago) by olson
Changes since 1.19: +0 -2 lines
Diff to previous 1.19
Remove debug warn.
Fri Jun 18 14:17:12 2004 UTC (15 years, 8 months ago) by olson
Changes since 1.18: +4 -1 lines
Diff to previous 1.18
Fix bad bug in publish checkbox code.
Wed Jun 16 16:52:10 2004 UTC (15 years, 8 months ago) by olson
Changes since 1.17: +1 -0 lines
Diff to previous 1.17
Modifications to fix & finish up the automated subsystem extension.
Wed Jun 16 14:07:13 2004 UTC (15 years, 8 months ago) by olson
Changes since 1.16: +65 -2 lines
Diff to previous 1.16
Add support for invoking the Prolog subsystem extension code.
Tue Jun 8 21:34:11 2004 UTC (15 years, 8 months ago) by olson
Changes since 1.15: +31 -6 lines
add code to do batch assignments
Tue Jun 8 20:25:51 2004 UTC (15 years, 8 months ago) by olson
Changes since 1.14: +83 -0 lines
add new stuff for show_msising
Mon Jun 7 19:11:33 2004 UTC (15 years, 8 months ago) by olson
fix delete button
Tue Jun 1 20:41:11 2004 UTC (15 years, 8 months ago) by olson
Changes since 1.12: +12 -0 lines
Add a call to db_sync() on the subsystem after it is written.
Wed May 26 22:33:56 2004 UTC (15 years, 8 months ago) by olson
only allow curator to publish
Wed May 26 22:32:15 2004 UTC (15 years, 8 months ago) by olson
Changes since 1.10: +6 -0 lines
Add ss_export functionality.
Thu May 20 13:38:37 2004 UTC (15 years, 9 months ago) by olson
Changes since 1.9: +51 -5 lines
add "show input to alignment tool" option
Wed May 19 21:34:23 2004 UTC (15 years, 9 months ago) by overbeek
Changes since 1.8: +5 -0 lines
fixed multiple identical rows in ssa due to import
Tue May 4 18:19:55 2004 UTC (15 years, 9 months ago) by olson
Changes since 1.7: +72 -11 lines
Added publish-to-clearinghouse support.
Reordered columns a bit.
Mon Apr 26 11:54:25 2004 UTC (15 years, 9 months ago) by overbeek
Changes since 1.6: +9 -6 lines
on refill for ssa2.cgi, there are no bad entries
Mon Apr 19 11:36:40 2004 UTC (15 years, 10 months ago) by overbeek
Changes since 1.5: +12 -4 lines
fix a bad bug in assignment permissions
Mon Apr 12 17:39:41 2004 UTC (15 years, 10 months ago) by overbeek
fix ugly bug in ssa2.cgi - failed to pass can_alter flag properly
Sat Apr 10 00:33:53 2004 UTC (15 years, 10 months ago) by overbeek
fix language in ssa intro
Fri Apr 9 22:29:30 2004 UTC (15 years, 10 months ago) by overbeek
Changes since 1.2: +172 -82 lines
minimal protection against overwriting
Fri Apr 2 18:14:45 2004 UTC (15 years, 10 months ago) by overbeek
Changes since 1.1: +10 -9 lines
fixes on ssa.cgi/ssa2.cgi
Fri Apr 2 18:02:21 2004 UTC (15 years, 10 months ago) by overbeek
add a new version of the spreadsheet software
