[Bio] / FigWebServices / ss_scoreboard.cgi Repository:
Log of /FigWebServices/ss_scoreboard.cgi
Links to rast_rel_2008_06_16: (view) (download) (annotate)
Mon Dec 5 19:12:12 2005 UTC (14 years, 4 months ago) by olson
Changes since 1.8: +17 -0 lines
add license words
Wed Jun 23 21:26:22 2004 UTC (15 years, 9 months ago) by olson
Changes since 1.7: +19 -0 lines
Make labels vertical.
Fix some bugs.
Wed May 26 14:04:33 2004 UTC (15 years, 10 months ago) by olson
Changes since 1.6: +25 -0 lines
More comments.
Tue May 25 20:32:04 2004 UTC (15 years, 10 months ago) by olson
Changes since 1.5: +0 -2 lines
remove debug
Tue May 25 20:30:45 2004 UTC (15 years, 10 months ago) by olson
Changes since 1.4: +60 -3 lines
Add sorting.
Tue May 25 20:11:20 2004 UTC (15 years, 10 months ago) by olson
Changes since 1.3: +3 -1 lines
fix defaults
Tue May 25 20:00:47 2004 UTC (15 years, 10 months ago) by olson
Changes since 1.2: +96 -5 lines
more scoreboard mods
Revision 1.2 - (view) (download) (annotate) - [selected]
Tue May 25 16:20:41 2004 UTC (15 years, 10 months ago) by olson
remove genome limit
Tue May 25 16:19:00 2004 UTC (15 years, 10 months ago) by olson
Diff to selected 1.2
scoreboard app
