[Bio] / FigWebServices / ss_export.cgi Repository:
Log of /FigWebServices/ss_export.cgi
Links to mgrast_rel_2008_0919: (view) (download) (annotate)
Revision 1.8 - (view) (download) (annotate) - [selected]
Mon Dec 5 19:12:12 2005 UTC (14 years, 7 months ago) by olson
Changes since 1.7: +17 -0 lines
add license words
Tue Jun 8 18:16:40 2004 UTC (16 years, 1 month ago) by olson
Changes since 1.6: +13 -6 lines
Make names more unique.
Mon Jun 7 19:58:21 2004 UTC (16 years, 1 month ago) by olson
Changes since 1.5: +19 -7 lines
mods for removing empty seqs from export
Thu May 27 19:28:08 2004 UTC (16 years, 1 month ago) by olson
Changes since 1.4: +29 -1 lines
Write a readme with role and genome definitions.
Thu May 27 18:47:05 2004 UTC (16 years, 1 month ago) by olson
more output writing fixes
Thu May 27 18:30:29 2004 UTC (16 years, 1 month ago) by olson
Changes since 1.2: +16 -4 lines
Thu May 27 17:19:05 2004 UTC (16 years, 1 month ago) by olson
Changes since 1.1: +21 -3 lines
export protein seqs, concatanted rows.
Wed May 26 22:32:15 2004 UTC (16 years, 1 month ago) by olson
Diff to selected 1.8
Add ss_export functionality.
