[Bio] / FigWebServices / ss_directed_compare_regions.cgi Repository:
Log of /FigWebServices/ss_directed_compare_regions.cgi
Revision 1.5 - (view) (download) (annotate) - [selected]
Tue Feb 10 20:28:47 2015 UTC (4 years, 10 months ago) by olson
CVS Tags: HEAD
Changes since 1.4: +5 -0 lines
link to ss editor, fix title
Tue Feb 10 20:15:01 2015 UTC (4 years, 10 months ago) by olson
Fixes
Tue Feb 10 19:59:29 2015 UTC (4 years, 10 months ago) by olson
Changes since 1.2: +14 -30 lines
Bob fixes
Tue Feb 10 16:50:41 2015 UTC (4 years, 10 months ago) by disz
Changed to use FIG_Config for data source
Mon Feb 9 18:16:38 2015 UTC (4 years, 10 months ago) by overbeek
Diff to selected 1.5
compare regions for ss columns
