[Bio] / FigWebServices / split_role_in_ss.cgi Repository:
Log of /FigWebServices/split_role_in_ss.cgi
Links to mgrast_release_3_1_2: (view) (download) (annotate)
Fri Sep 11 21:11:12 2009 UTC (10 years, 5 months ago) by overbeek
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.3: +11 -3 lines
minor fixes
Wed Aug 19 19:08:02 2009 UTC (10 years, 6 months ago) by overbeek
Changes since 1.2: +29 -8 lines
fixes to support marking frameshifts and comments
Mon Aug 10 20:47:30 2009 UTC (10 years, 6 months ago) by overbeek
sort subsystems
Mon Aug 10 18:50:20 2009 UTC (10 years, 6 months ago) by overbeek
a tool for annotators
