[Bio] / FigWebServices / show_log.cgi Repository:
Log of /FigWebServices/show_log.cgi
Links to MAIN: (view) (download) (annotate)
Sun May 7 04:04:40 2006 UTC (13 years, 11 months ago) by overbeek
Changes since 1.2: +8 -0 lines
add ability to log arbitrary correspondences
Sat May 6 19:25:15 2006 UTC (13 years, 11 months ago) by overbeek
Changes since 1.1: +46 -3 lines
add ability to show maps in log
Fri May 5 16:43:09 2006 UTC (13 years, 11 months ago) by overbeek
crude version of show_log.cgi
