[Bio] / FigWebServices / show_local_map.cgi Repository:
Log of /FigWebServices/show_local_map.cgi
Links to rast_release_2008_09_29: (view) (download) (annotate)
Thu Sep 28 22:59:05 2006 UTC (13 years, 6 months ago) by redwards
fixing broken links on map pages that refered fig ids to KEGG
Mon Dec 5 19:12:12 2005 UTC (14 years, 3 months ago) by olson
add license words
Mon Aug 1 16:29:22 2005 UTC (14 years, 7 months ago) by olson
CVS Tags: caBIG-00-00-00
Replace use of $FIG_Config::cgi_url with &FIG::cgi_url()
Wed Jun 23 15:41:33 2004 UTC (15 years, 9 months ago) by disz
local map fixes, removed extra subsystem logon lines
Wed Jun 16 15:10:48 2004 UTC (15 years, 9 months ago) by olson
new file
