[Bio] / FigWebServices / sgv.cgi Repository:
Log of /FigWebServices/sgv.cgi
Links to rast_rel_2014_0912: (view) (download) (annotate)
Tue Feb 23 21:46:30 2010 UTC (10 years, 3 months ago) by parrello
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.8: +8 -1 lines
Fixed temporary directory setup for Genographics. Changed seed viewer URL computation.
Revision 1.8 - (view) (download) (annotate) - [selected]
Fri Feb 19 19:37:17 2010 UTC (10 years, 3 months ago) by olson
Changes since 1.7: +6 -0 lines
fixes for new genographics
Wed Feb 17 19:34:44 2010 UTC (10 years, 3 months ago) by parrello
Changes since 1.6: +12 -14 lines
Fixed tooltips on compare regions display.
Mon Dec 14 20:42:01 2009 UTC (10 years, 5 months ago) by overbeek
CVS Tags: rast_rel_2010_0118
Changes since 1.5: +25 -9 lines
minor fixes
Mon Dec 14 15:53:16 2009 UTC (10 years, 5 months ago) by overbeek
Changes since 1.4: +29 -3 lines
handle empty tables gracefully
Mon Dec 14 15:00:14 2009 UTC (10 years, 5 months ago) by overbeek
Changes since 1.3: +34 -12 lines
fixes
Mon Dec 14 02:36:52 2009 UTC (10 years, 5 months ago) by overbeek
Changes since 1.2: +5 -2 lines
do not show inactive subsys
Mon Dec 14 02:27:14 2009 UTC (10 years, 5 months ago) by overbeek
fix coord
Mon Dec 14 02:10:48 2009 UTC (10 years, 5 months ago) by overbeek
Diff to selected 1.8
a basic genome directory viewer
