[Bio] / FigWebServices / server_check.cgi Repository:
Log of /FigWebServices/server_check.cgi
Links to mgrast_version_3_2: (view) (download) (annotate)
Mon Dec 5 19:12:12 2005 UTC (14 years, 4 months ago) by olson
add license words
Wed Jul 13 19:35:25 2005 UTC (14 years, 8 months ago) by olson
CVS Tags: caBIG-00-00-00
Changes since 1.1: +10 -0 lines
Add an error CGI param to allow a forced failure for nagios debugging.
Wed Jul 13 19:08:36 2005 UTC (14 years, 8 months ago) by olson
Check the status of the SEED server. Return an HTTP error code if there is a problem.
Used for nagios monitoring of SEED servers.
