[Bio] / FigWebServices / serv_subsysRow.cgi Repository:
Log of /FigWebServices/serv_subsysRow.cgi
Links to mgrast_release_3_1_2: (view) (download) (annotate)
Tue Nov 29 21:17:15 2011 UTC (8 years, 2 months ago) by disz
CVS Tags: mgrast_dev_12152011, mgrast_release_3_1_2
Changes since 1.2: +10 -55 lines
New interafce fixups
Mon Nov 28 17:37:45 2011 UTC (8 years, 2 months ago) by overbeek
Changes since 1.1: +50 -0 lines
new UI stuff
Thu Nov 17 01:09:00 2011 UTC (8 years, 3 months ago) by overbeek
initial subsystems row
