[Bio] / FigWebServices / serv_role.cgi Repository:
Log of /FigWebServices/serv_role.cgi
Links to mgrast_release_3_1_2: (view) (download) (annotate)
Tue Nov 29 21:17:15 2011 UTC (8 years ago) by disz
CVS Tags: mgrast_dev_12152011, mgrast_release_3_1_2
Changes since 1.1: +8 -53 lines
New interafce fixups
Mon Nov 28 17:37:45 2011 UTC (8 years ago) by overbeek
new UI stuff
