[Bio] / FigWebServices / serv_role.cgi Repository:
Log of /FigWebServices/serv_role.cgi
Wed Apr 11 20:35:29 2012 UTC (7 years, 7 months ago) by overbeek
CVS Tags: HEAD, mgrast_version_3_2, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.4: +6 -0 lines
mods suggested by Bob
Revision 1.4 - (view) (download) (annotate) - [selected]
Fri Dec 16 17:53:25 2011 UTC (7 years, 11 months ago) by disz
Changes since 1.3: +5 -2 lines
Changed sapdb
Tue Dec 13 21:22:30 2011 UTC (7 years, 11 months ago) by disz
Changes since 1.2: +18 -3 lines
Fixed up parameter passing
Tue Nov 29 21:17:15 2011 UTC (8 years ago) by disz
CVS Tags: mgrast_dev_12152011, mgrast_release_3_1_2
Changes since 1.1: +8 -53 lines
New interafce fixups
Mon Nov 28 17:37:45 2011 UTC (8 years ago) by overbeek
Diff to selected 1.4
new UI stuff
