[Bio] / FigWebServices / serv_otu.cgi Repository:
Log of /FigWebServices/serv_otu.cgi
Links to rast_rel_2014_0729: (view) (download) (annotate)
Wed Apr 11 20:35:29 2012 UTC (7 years, 9 months ago) by overbeek
CVS Tags: HEAD, mgrast_version_3_2, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.3: +7 -2 lines
mods suggested by Bob
Fri Dec 16 17:53:25 2011 UTC (8 years, 1 month ago) by disz
Changes since 1.2: +5 -2 lines
Changed sapdb
Tue Dec 13 21:22:30 2011 UTC (8 years, 1 month ago) by disz
Changes since 1.1: +20 -4 lines
Fixed up parameter passing
Wed Nov 30 16:32:13 2011 UTC (8 years, 1 month ago) by disz
CVS Tags: mgrast_dev_12152011, mgrast_release_3_1_2
New ui stuff
