[Bio] / FigWebServices / select.cgi Repository:
Log of /FigWebServices/select.cgi
Links to mgrast_release_3_1_2: (view) (download) (annotate)
Tue Apr 29 08:15:20 2008 UTC (11 years, 9 months ago) by parrello
Added Etracing support.
Fri Dec 15 03:23:45 2006 UTC (13 years, 2 months ago) by parrello
CVS Tags: rast_rel_2008_04_23
Changes since 1.13: +65 -32 lines
Converted to use new attribute system.
Sat Aug 26 22:28:24 2006 UTC (13 years, 5 months ago) by redwards
correct array deref
Sat Aug 26 22:15:40 2006 UTC (13 years, 5 months ago) by redwards
Changes since 1.11: +12 -4 lines
correcting an ss names bug
Wed May 10 15:47:57 2006 UTC (13 years, 9 months ago) by overbeek
RAE: adding new excel functions
Mon May 8 01:43:31 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.9: +3 -1 lines
RAE: Adding a color to 0 variant codes
Sun May 7 20:10:07 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.8: +1 -0 lines
RAE: Updating excel writing functions
Sat May 6 22:04:12 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.7: +9 -3 lines
RAE: Adding writing excel tables to raelib, html, and initial trial in select.cgi
Tue Apr 4 01:52:11 2006 UTC (13 years, 10 months ago) by overbeek
Changes since 1.6: +2 -2 lines
RAE: Case insensitive sorting
Mon Apr 3 18:48:15 2006 UTC (13 years, 10 months ago) by overbeek
Changes since 1.5: +14 -17 lines
RAE: Adding functional coupling paper to list of projects
Thu Mar 23 05:29:34 2006 UTC (13 years, 11 months ago) by overbeek
Changes since 1.4: +4 -0 lines
RAE: Adding divider cols with labels
Wed Mar 22 23:52:43 2006 UTC (13 years, 11 months ago) by overbeek
Changes since 1.3: +5 -0 lines
RAE: adding extra col hdrs
Wed Mar 22 16:31:16 2006 UTC (13 years, 11 months ago) by overbeek
RAE: making 0 and -1 work
Sun Mar 19 22:23:34 2006 UTC (13 years, 11 months ago) by overbeek
Changes since 1.1: +44 -10 lines
RAE: Updating the select.cgi interface
Sun Mar 19 21:30:56 2006 UTC (13 years, 11 months ago) by overbeek
RAE: Initial release of setting.cgi and format changes on subsys.cgi
