[Bio] / FigWebServices / seed_running_perl.fragment Repository:
Log of /FigWebServices/seed_running_perl.fragment
Links to merge-trunktag-bobdev_news-2: (view) (download) (annotate)
Tue May 4 16:29:13 2004 UTC (15 years, 7 months ago) by olson
CVS Tags: Root-bobdev_news, caBIG-00-00-00, caBIG-05Apr06-00, caBIG-13Feb06-00, merge-bobdev_news-1, merge-bobdev_news-2, merge-bodev_news-3, merge-trunktag-bobdev_news-1, merge-trunktag-bobdev_news-2, merge-trunktag-bodev_news-3
Fragment of perl code to be inserted between tool_hdr and
actual script of CGI; checks to see if SEED running before allowing CGI script
to go.
