[Bio] / FigWebServices / seed_ctl.cgi Repository:
Log of /FigWebServices/seed_ctl.cgi
Links to rast_rel_2014_0729: (view) (download) (annotate)
Mon Oct 29 15:57:26 2007 UTC (12 years, 2 months ago) by olson
Changes since 1.12: +7 -0 lines
add ability to disable just the control panel.
Thu Feb 15 21:28:50 2007 UTC (12 years, 11 months ago) by olson
Changes since 1.11: +19 -10 lines
fix ctl for broken db
Tue Mar 7 17:19:05 2006 UTC (13 years, 10 months ago) by overbeek
Changes since 1.10: +9 -0 lines
Disable this too.
Mon Dec 5 19:12:12 2005 UTC (14 years, 1 month ago) by olson
Changes since 1.9: +17 -0 lines
add license words
Wed Jul 20 04:08:43 2005 UTC (14 years, 6 months ago) by redwards
CVS Tags: caBIG-00-00-00
Changes since 1.8: +2 -1 lines
seed_ctl was not working
Sun Jul 10 01:27:19 2005 UTC (14 years, 6 months ago) by redwards
Changes since 1.7: +1 -0 lines
title for seed_ctl
Sun Jul 10 01:05:36 2005 UTC (14 years, 6 months ago) by redwards
Changes since 1.6: +17 -6 lines
Allow deleting jobs from seed_ctl.cgi
Sat Apr 9 17:21:16 2005 UTC (14 years, 9 months ago) by redwards
Changes since 1.5: +22 -2 lines
changes to seed_ctl and raelib
Sun Apr 3 19:33:59 2005 UTC (14 years, 9 months ago) by redwards
Changes since 1.4: +5 -2 lines
color seed_ctl.cgi
Mon Dec 6 18:31:02 2004 UTC (15 years, 1 month ago) by olson
Changes since 1.3: +29 -0 lines
add job scheduler status stuff
Wed Jun 16 14:06:48 2004 UTC (15 years, 7 months ago) by olson
Changes since 1.2: +55 -33 lines
Revamp background job stuff.
Mon Jun 14 22:05:38 2004 UTC (15 years, 7 months ago) by olson
Changes since 1.1: +15 -22 lines
update background job display
Thu Apr 1 20:59:35 2004 UTC (15 years, 9 months ago) by olson
Control panel.
