[Bio] / FigWebServices / search_log.cgi Repository:
Log of /FigWebServices/search_log.cgi
Links to rast_rel_2008_06_16: (view) (download) (annotate)
Revision 1.3 - (view) (download) (annotate) - [selected]
Wed Jun 14 22:11:08 2006 UTC (14 years ago) by hwang
Change absolute path to relative path for getting genome log data
Wed Jun 14 21:43:47 2006 UTC (14 years ago) by hwang
Added location of tarfile
Wed Jun 14 21:22:04 2006 UTC (14 years ago) by hwang
Diff to selected 1.3
This cgi is to allow searching and viewing of the log tables.
Based on ross's show_log.cgi
