[Bio] / FigWebServices / save_to_attributes.cgi Repository:
Log of /FigWebServices/save_to_attributes.cgi
Links to mgrast_rel_2008_1110: (view) (download) (annotate)
Tue Mar 20 18:15:29 2007 UTC (13 years, 2 months ago) by hwang
Changes since 1.5: +16 -5 lines
Add in routines that save the attributes to ROLE_FROM_PEG_CURATED_RELEVANT
Thu Jan 18 21:31:49 2007 UTC (13 years, 4 months ago) by hwang
Changes since 1.4: +7 -7 lines
Take out debugging
Thu Jan 18 19:21:52 2007 UTC (13 years, 4 months ago) by hwang
Changes since 1.3: +95 -70 lines
File was updated to use the Bruce's even newer attribute server. deletion of attributes must include all the fields.
Tue Nov 28 21:38:48 2006 UTC (13 years, 5 months ago) by hwang
take out print statements
Tue Nov 28 20:11:41 2006 UTC (13 years, 5 months ago) by hwang
Changes since 1.1: +74 -65 lines
Changed curation of attributes since there is now an attribute server.
Changed code to allow functional roles to access attributes
Fri Sep 8 20:38:31 2006 UTC (13 years, 8 months ago) by hwang
Gives information that an attribute have been added
