[Bio] / FigWebServices / samples.cgi Repository:
Log of /FigWebServices/samples.cgi
Mon Dec 2 17:06:31 2013 UTC (5 years, 11 months ago) by overbeek
Changes since 1.4: +8 -6 lines
progress
Sun Dec 1 14:34:47 2013 UTC (5 years, 11 months ago) by overbeek
Changes since 1.3: +86 -1 lines
add ar-names
Sat Nov 30 03:05:28 2013 UTC (5 years, 11 months ago) by overbeek
Changes since 1.2: +65 -5 lines
support ARs making up sample
Thu Nov 28 21:12:59 2013 UTC (5 years, 11 months ago) by overbeek
seprate windows
Thu Nov 28 17:59:18 2013 UTC (5 years, 11 months ago) by overbeek
ER model for Bacillus subtilis - mildly generalized
