[Bio] / FigWebServices / reset_curator.cgi Repository:
Log of /FigWebServices/reset_curator.cgi
Links to mgrast_dev_04052011: (view) (download) (annotate)
Wed Jun 21 19:50:25 2006 UTC (13 years, 9 months ago) by overbeek
RAE: adding options to reset_curator
Wed Jun 21 17:16:38 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.2: +21 -8 lines
Mon Dec 5 19:12:12 2005 UTC (14 years, 4 months ago) by olson
add license words
Sat Feb 26 11:01:13 2005 UTC (15 years, 1 month ago) by overbeek
add reset_curator.cgi
