[Bio] / FigWebServices / record.cgi Repository:
Log of /FigWebServices/record.cgi
Links to mgrast_release_3_1_2: (view) (download) (annotate)
Mon Dec 5 19:12:12 2005 UTC (14 years, 2 months ago) by olson
add license words
Wed Nov 17 16:17:59 2004 UTC (15 years, 3 months ago) by overbeek
Changes since 1.2: +7 -7 lines
fixes to record.cgi
Wed Nov 17 14:41:06 2004 UTC (15 years, 3 months ago) by overbeek
minor fix to record.cgi
Wed Nov 17 14:40:19 2004 UTC (15 years, 3 months ago) by overbeek
fix URL in HTML.pm and add record.cgi
