[Bio] / FigWebServices / protein_by_ss.cgi Repository:
Log of /FigWebServices/protein_by_ss.cgi
Links to rast_release_2008_09_29: (view) (download) (annotate)
Thu Oct 25 22:42:44 2007 UTC (12 years, 3 months ago) by redwards
Changes since 1.5: +8 -84 lines
undoing horrible mistake
Thu Oct 25 22:21:28 2007 UTC (12 years, 3 months ago) by redwards
Changes since 1.4: +84 -8 lines
changing the makewsdl script to a live cgi
Mon Dec 5 19:12:12 2005 UTC (14 years, 2 months ago) by olson
add license words
Fri Oct 14 16:26:15 2005 UTC (14 years, 4 months ago) by mkubal
CVS Tags: caBIG-00-00-00
Changes since 1.2: +47 -4 lines
now has both search by alias and search_index options for standard ids and other identifiers respectively
Wed Oct 12 00:46:19 2005 UTC (14 years, 4 months ago) by mkubal
Changes since 1.1: +2 -5 lines
removed writes to STDERR
Wed Oct 12 00:43:59 2005 UTC (14 years, 4 months ago) by mkubal
takes list of gene/prot ids and returns table with ss and cluster info
