[Bio] / FigWebServices / pom.cgi Repository:
Log of /FigWebServices/pom.cgi
Fri Oct 5 18:33:12 2007 UTC (12 years, 1 month ago) by overbeek
Changes since 1.21: +16 -4 lines
Diff to previous 1.21
add check_variants.cgi, a program to automatically validate variant codes
Fri Aug 10 01:13:43 2007 UTC (12 years, 3 months ago) by overbeek
Changes since 1.20: +33 -39 lines
Diff to previous 1.20
fixes to pom.cgi
Mon Mar 12 13:39:05 2007 UTC (12 years, 8 months ago) by overbeek
Changes since 1.19: +1 -0 lines
Diff to previous 1.19
fixes to allow non-peg features in subsystems
Sat Jan 28 17:25:32 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.18: +54 -20 lines
Diff to previous 1.18
RAE: Updating POM with new entry page
Sat Jan 28 04:23:48 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.17: +44 -3 lines
Diff to previous 1.17
RAE: Updating POM -- pieces of metabolism
Fri Jan 27 05:10:12 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.16: +216 -63 lines
Diff to previous 1.16
RAE: pom.cgi update
Mon Dec 5 19:12:12 2005 UTC (13 years, 11 months ago) by olson
Changes since 1.15: +17 -0 lines
add license words
Wed Oct 12 21:03:16 2005 UTC (14 years, 1 month ago) by overbeek
CVS Tags: caBIG-00-00-00
Changes since 1.14: +5 -5 lines
Mon Jun 14 22:53:55 2004 UTC (15 years, 5 months ago) by overbeek
Changes since 1.13: +34 -28 lines
fix bug in locating candidates for role
Tue Jun 8 21:33:50 2004 UTC (15 years, 5 months ago) by olson
Changes since 1.12: +2 -2 lines
bugfix for try_to_locate call
Tue Jun 8 20:25:34 2004 UTC (15 years, 5 months ago) by olson
Changes since 1.11: +56 -0 lines
add some comments
Sun May 9 12:42:44 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.10: +46 -19 lines
fixed occurrences by similarity
Tue Apr 27 15:41:28 2004 UTC (15 years, 6 months ago) by overbeek
basic query tools
Tue Mar 9 23:19:23 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.8: +1 -34 lines
fixed distances and spreadsheet
Mon Feb 23 23:38:57 2004 UTC (15 years, 8 months ago) by overbeek
add lengths to search for function
Fri Feb 20 14:34:56 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.6: +2 -2 lines
fix expansion parm bug
Wed Jan 14 20:20:32 2004 UTC (15 years, 10 months ago) by overbeek
Changes since 1.5: +13 -2 lines
synch up Ross
Fri Jan 2 20:30:27 2004 UTC (15 years, 10 months ago) by overbeek
Changes since 1.4: +3 -3 lines
use literal for complete
Fri Jan 2 20:22:28 2004 UTC (15 years, 10 months ago) by overbeek
Changes since 1.3: +3 -3 lines
pom.cgi and sig.cgi should consider only complete genomes
Tue Dec 16 16:59:42 2003 UTC (15 years, 11 months ago) by efrank
Changes since 1.2: +0 -13 lines
Removed stray tool_hdr content that got copied in here
Wed Dec 3 21:24:31 2003 UTC (15 years, 11 months ago) by overbeek
CVS Tags: delong-01, delong-02
Changes since 1.1: +15 -1 lines
Mon Dec 1 16:57:09 2003 UTC (15 years, 11 months ago) by efrank
Branch: initial
CVS Tags: V00-00-00, V00-00-01, V00-00-02, init, preRossMerge-03Dec03
Diff to previous 1.1 , to next main 1.22
import
Branch point for: initial
